Re: Cub ignition
Posted by garyandnancy on January 03, 2010 at 11:23:52 from (64.136.26.230):
In Reply to: Cub ignition posted by garyandnancy on January 02, 2010 at 12:55:56:
OK, got it figured out, it was very strange. The governor /mag drive gear was not correctly timed. Pulled of the front of the tractor and then pulled off the governor. It seems that whoever had the tractor apart did not time the idler correctly as it’s marks were way off. Not wanting to deal with the crank pulley, we set the engine at TDC on ##1 and then inserted the governor gear so that its timing mark meshed with the teeth on the idler. Put it back together and presto, it started right up. Thanks for your help.
