Re: Poor Running 340 Utility When Warm
Posted by jesse007 on January 03, 2010 at 15:35:56 from (142.154.169.130):
In Reply to: Poor Running 340 Utility When Warm posted by Michigan IH on January 03, 2010 at 13:54:05:
Hello sir,
As you are probably well aware a U or F 340 is normally a smooth sweet running machine with adequate power and good fuel economy.
Here are the items I would check if it were my 340:the carburetor float level and action to make sure it isn"t sticking so the float can regulate the fuel level properly,check for partially plugged jets,try another set of spark plugs especially an old set if you knew they worked properly-I have had some hideous experiences with new but defective plugs that had symptoms a lot like you are experiencing,you might try another condenser or coil if all else fails-if you give me your phone number and a convenient time to call I"ll try to help you that way
take care and good luck!
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
