Posted by Michigan IH on January 03, 2010 at 13:54:05 from (198.208.159.20):
My gas 340 utility runs fine when first started, but after 20 or 30 minutes (especially if idling) it starts to run like the choke is out. It stumbles and sputters when you give it gas, it does the same when it encounters a load. Sometimes it will back fire through the exhaust. It has 1900 hours on the meter. I installed a new crank at 1400 hours but have not had the head off. This condition occurs in cold or warm weather. In addition to the poor running, the carb is also wet on the outside all the time and moisture comes down the block from the manifold runners. I tried a heat houser last winter with no impact. Any ideas??
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
