Re: When did engines start using high detergent oils?
Posted by Richardin52 on January 03, 2010 at 19:02:10 from (24.39.46.126):
In Reply to: When did engines start using high detergent oils? posted by Richardin52 on January 03, 2010 at 18:43:17:
I just read some old posts on the subject. Sounds like the smart thing to do is to drop the oil pan and if there is a bunch of crud clean it out then do the same thing to the valve cover. Then if the engine is clean put in detergent oil and change it just as soon as you see any color for a few times.
The jeep had been setting in a barn for a long time before my son got it. What do you want a bet it was put up with dirty oil and the pan was full of crud.
