Re: When did engines start using high detergent oils?
Posted by ScottyHOMEy on January 03, 2010 at 19:29:48 from (70.105.242.5):
In Reply to: Re: When did engines start using high detergent oils? posted by Richardin52 on January 03, 2010 at 19:02:10:
I'd suspect the laying up had more to do with it than the detergent factor in the oil. If it set for a long time, there's a good chance there was a lot of water from condensation in the pan.
Detergent oils get a bad name in cases like this because of the hype given to laundry detergents. Honest, they don't act like Scrubbin Bubbles. They do contain a surfactant, that will bond with surface crud and carry it to the filter. They do NOT break things up. A good surfactant in an oil will loosen stuff up well, floating it off the surface of any sludge, but gradually, so it is important, as you observe, to change oils and filters more frequently when changing over.
That said, there was a version of the later 5.9 Cummins in Dodge pickups that would "look" dirty after 500 miles, but would test as perfectly good, serviceable oil.
Depending on what you mean by the motor being "blown". . . if it truly is blown (i.e., rod or main bearings chewed up with the dmgage to the crank that goes with it, or broken rings . . .) a cleanup and oil change isn't going to help it. I
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
