Re: Poor Running 340 Utility When Warm
Posted by MN Mike on January 04, 2010 at 04:59:04 from (216.77.154.39):
In Reply to: Poor Running 340 Utility When Warm posted by Michigan IH on January 03, 2010 at 13:54:05:
the only thing I'll add to the great suggestions is to check your condensor and points. I replaced a pitted set of points on my 340 last spring and found a motor that ran a lot better under load.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
