Drain all the oils (leave rear end oil in for now)& fluids, including gas if any left in the tank. Remove sparkplugs & fill cylinders with Marvel Mystery Oil and leave. Remove carb & place in a can of carb cleaner & allow to soak.
If tractor has a hand crank turn the engine over once a day & keep refilling cylinders with Marvel Mystery Oil. After carb has soaked buy a rebuild kit & rebuild it, being sure to clean gunk out of all passageways.
Crank engine over to remove MMO, then install new plugs, points & condensor , replace carb, & put new gas in the tank. Refill engine oil, replace oil filter, & fill rad. Finally, see if the old gal will start. If you can get it to run then drain rear end oil & replace with diesel fuel. Drive trac tor 1/4 mile or so, drain diesel fuel & put new rear emdoil in.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
