Where to start on a 1943 M
Posted by Charles Tichenor on January 05, 2010 at 20:12:37 from (70.150.134.9):
I have 1943 M that has sat for probably close to 35-40 years. The good news is that is has always been in a barn, all the parts are there and the motor is not locked up. The tractor was in good working order when it was parked (or so my grandfather says). I am looking for recommendations on how to approach trying to get the tractor started, what items you would initially replacement before trying to start it.
Thanks
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
