Re: Where to start on a 1943 M
Posted by glennster on January 06, 2010 at 05:54:24 from (76.217.99.179):
In Reply to: Where to start on a 1943 M posted by Charles Tichenor on January 05, 2010 at 20:12:37:
couple other things i"d check too, pull the valve cover, and lube up the valve train real good with automatic trans fluid, check the valve train while cranking the motor over by hand to see if any valves are stuck. i"d also go over all the lube points on the tractor and give em a couple pumps of fresh grease, especially the water pump and the distributor. (there are 2 flat blade screw type plugs on the distributor, pull them out, screw in a zerk and give em a couple pumps. (i didnt do that on an m i did years ago and tore up a set of gears after the tractor was running. ) it was delco distributor.
