Depends a lot on where you are in cold climates you will probaly have lots of codensation in engine and rear, in warm climate this is not a problem. I pullled cotton picker off 1940 M few years ago that had sat in open front pole barn for about 30 years. After checking out ignition putting oil in cylinders, changing oil and filter it fired right up and ran good. Had to pull frame cover to flip ring gear and there was not a trace of rust in rear end. Contrary to what everone says the only oil leak it has after being used several years is slight leak behind govener.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
