Re: Replacing a Charlynn output shaft coupling on an H
Posted by mkirsch on January 07, 2010 at 05:12:52 from (64.80.108.55):
In Reply to: Replacing a Charlynn output shaft coupling on an H posted by nt moore on January 06, 2010 at 18:37:56:
That seal won't be leaking because there probably isn't any oil in the gearbox. Most of them have been pumped full of gun grease because the bottom seal is shot, and it's a chore to replace.
Simply remove the grille, turn out that pipe plug, and roll the steering shaft, worm gear, and bearing assembly out by rotating it. Then you'll have plenty of room.
