I did mine exactly as mkirsch describes - unscrewed the front plug then rolled the worm/bearing/shaft assembly forward.
If the input shaft seal is worn out don't worry about it. Simply pack the gear box full with good quality grease before you put the cover back on.
Tip: Use new roll pins at both ends of the coupling (should be a small one nested inside a larger one).
When I took mine apart I found an inner pin was missing and the outer one cracked. It was simple good luck the cracked pin hadn't sheared resulting in a loss of steering.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
