Re: H heater hose tee.
Posted by d7fever on January 07, 2010 at 07:14:05 from (71.127.10.224):
In Reply to: H heater hose tee. posted by ryanwheelock on January 07, 2010 at 05:58:39:
They used them on a lot of old cars too. What they are is a piece of steel tubing,, or brass, with a curved piece on one end, then threaded , with a curved piece that you put on and tighten down with a nut. after you cut a hole in the hose and put the thing thru. You can find them in old car parts catalogues, I think that Drakes and probably Carpenter's has them.
