Re: H heater hose tee.
Posted by jal-SD on January 07, 2010 at 08:04:31 from (97.114.149.78):
In Reply to: H heater hose tee. posted by ryanwheelock on January 07, 2010 at 05:58:39:
On my H, I took out the block drain plug, installed a nipple (3/8" if I remember right), & put a short hose to the bottom of the tank heater. Then I took out the heat guage bulb, installed a short nipple & "T", put the heat guage bulb in the straight side of the "T" and connected the top hose from the tank heater to a short nipple in the bottom of the "T". Heat guage reads a little low, but works OK. Always thought of taking the plug out of the stat housing & plumbing it into there, but don't know if that would work as good. Have to plug it in at noon, -7 here now with a 20 MPH wind and about 8" of new snow on top of the 20" we got during Christmas. Don't know where I'm going to pile it from the drive tonight. (My $0.02 worth. jal-SD)
