Re: H heater hose tee.
Posted by Janicholson on January 07, 2010 at 10:52:53 from (199.17.6.222):
In Reply to: H heater hose tee. posted by ryanwheelock on January 07, 2010 at 05:58:39:
Your lower hose is from a different vehicle. No issue, it is just not original. Using it for the lower heater port will work. Most use the drain plug behind the carb area for the lower hose. JimN
