Steven, The relief for the 3pt. is under the square plate under the seat as Tractorman said. Remove the seat & cover. The hitch relief is in the right front corner. Try to lift a bale & see if oil comes out the top of the relief. If it does you can screw the slotted part of the valve in to raise the pressure. Try a 1/4 turn at a time. Have done this many times to raise a heavy planter with no problems. Just go enough to raise the bale. If the valve does not leak when trying to lift your pump is probably weak.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
