Re: 656 3pt lift problem
Posted by bc on January 08, 2010 at 19:00:14 from (71.158.222.215):
In Reply to: Re: 656 3pt lift problem posted by Ted in NE on January 08, 2010 at 07:05:24:
Ted, my 2606 has hydraulics like the 656. That slotted bypass valve in the right front corner of the rock shaft housing was factory notched into the threads so it wouldn't turn. I tried. There was also another bypass valve in the block on the outside and right side of the housing. Its a flat/low looking bolt head that takes about a 7/8 or so socket. Easy to strip and mine was already stripped so I got it with an impact wrench.
One for each pump. I think the inside one was fed from the block on the front at the right front corner of the housing.
If he pulls the plate off the housing, lift it straight and don't burger the gasket under it.
