You are certainly free to continue doing as you please. If it works for you fine. As far as me trying it, been there, done that, 50 years of it and still trying. Works great on closed center, doesn't change flow on open. Like another poster said, if you restrict the flow with your hose to build pressure , of course it will build some more heat. We always use that method to heat systems using a flow rater so we can watch the temp as we need it to be up to specs to do tests. Maybe you are using a small hose enough hose to create a pressure rise. Other wise, oil is just taking a slightly different route to sump. Like the length of your hose.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
