Re: Warming up the MCV on 706
Posted by Lee in Iowa on January 08, 2010 at 12:18:03 from (66.172.198.123):
In Reply to: Re: Warming up the MCV on 706 posted by pete 23 on January 08, 2010 at 10:34:08:
I'm using a 3/8 hose with no other restrictions and you can tell the difference like I said even after the tractor is warmed up the oil will cool back off a lot more if you don't pump it thru the hose while it idles. I don't have a primimg problem with my tractor, but the neighbor did with his 1066 and it primes a lot quicker running oil thru a 1/2 hose. Maybe it won't warm the oil in a warm shop setting, but I know it has helped in the below zero outside temps feeding cattle the last 40 years.
