Re: Calling Brian Schmidt.....
Posted by Red Mist on January 09, 2010 at 17:39:50 from (67.142.130.18):
In Reply to: Calling Brian Schmidt..... posted by D Slater on January 09, 2010 at 11:22:00:
What is your technique for removal of the guide lens from the housing/reflector? I experimented with a light with a bad housing body (had rust holes through the back) and found that I could pry the crimp off the lens by first grinding (thinning) the outer edge of the metal crimp.
I also tried using a reflector w/bulb socket from an IH (older) bulb type light. It would fit the pancake housing with a little grinding of the edge, but had a bent lip around the circumference which prevented it from seating to a proper depth for both the gasket and rim - together. I could put it together without a rubber gasket, but that would not be good for the long haul...... Thanks.
mike
This post was edited by Red Mist at 17:48:13 01/09/10 2 times.
