Re: Calling Brian Schmidt.....
Posted by Brian Schmidt on January 10, 2010 at 16:18:11 from (69.66.233.155):
In Reply to: Re: Calling Brian Schmidt..... posted by Red Mist on January 09, 2010 at 17:39:50:
I simply work around the edge with a small screw driver carefully straightening the crimp out. Once I got the lens out, I go around the edge with needle nose pliers to further straighten out the edge.
No grinding is necessary. You could try using the older style reflectors, but will end up with the same results as I do, but waste an old reflector that you might need some day for another tractor. If I remember correctly, the light sockets at Autozone are like $2 or less.
When I get some pictures ready, I will be post them here as well. Enough are interested, I may do it early in the house.
