Re: 1964 806 Timing.... Allen in NE?
Posted by Larry B 1486 on January 10, 2010 at 10:03:55 from (67.142.161.32):
In Reply to: 1964 806 Timing.... Allen in NE? posted by Dan Swanson on January 10, 2010 at 09:42:36:
Sounds like the injector pump if your motor is tight with good comperssion. You do not have to change the timing having added a turbo. Someone thought it might get a little mower power out of it by bumping up the timing but not nessary just because you added a turbo to a 361 motor. Adding a turbo on thoes tractors, check your air filter more often because they get more dirt sucked in if they are the orignal filter. On one of my 806's I changed the air filter to one off a 856 diesel. Larger filter.
