1964 806 Timing.... Allen in NE?
Posted by Dan Swanson on January 10, 2010 at 09:42:36 from (63.172.252.199):
I posted this question several months ago and no one seemed to know the answer. Here goes again - My 806 has an after market M&W turbo on it. Needs a shot of ether for anything less than 60 degrees or so. The timing for a natural aspired diesel 806 is 8 degrees BTDC, per owners manual. Mine is set at 6 degrees BTDC. Is this necessary because of the turbo? Would changing it back to 8 deg. possibly help with the hard starting? I know there are several other possible issues that play into it hard starting. But my main question is about the timing, if it is correct or not. Thanks, Dan Swanson
