Re: 1964 806 Timing.... Allen in NE?
Posted by pete 23 on January 10, 2010 at 10:21:29 from (173.87.15.32):
In Reply to: 1964 806 Timing.... Allen in NE? posted by Dan Swanson on January 10, 2010 at 09:42:36:
It may help but not likely. The 1206 used a smaller total degree of automatic advance at full throttle due to the turbo. So it depends on what your pump advance total is to make a determination as to where to put the static timing. Also the 856 used more advance than an 806 and when a lot of pumps are rebuilt they are rebuilt or replaced with 856 pumps so when put on an 806 you retard injection to that 6 degree setting to compensate for this. I guess what I am saying is , if it doesn't make it start any better by going to 8 degree static timing I would put it back to 6 for better full load performance. I don't have my service manual handy right now or I could look up the actual specs.
