Re: 1964 806 Timing.... Allen in NE?
Posted by caseyc on January 10, 2010 at 18:19:59 from (66.6.1.11):
In Reply to: 1964 806 Timing.... Allen in NE? posted by Dan Swanson on January 10, 2010 at 09:42:36:
i have to agree with the rest. if the motor is tight then you need a new injection pump. did you put the turbo on it? how long has it been on? how are the piston rings? checking compression on the motor would be my first step....
casey in SD
