Re: 130 hydraulic pump leaking
Posted by El Toro on January 12, 2010 at 07:19:11 from (74.103.74.58):
In Reply to: 130 hydraulic pump leaking posted by S MacKay on January 12, 2010 at 07:07:45:
third party image
Your pump is probably similar to this Pesco pump parts breakdown. You should check item No11
to see if item No4 has worn a groove on it. Speedi-sleeves are available to cover that groove if it has one. Hal
