Re: C-123 Camshaft
Posted by Stan(VA). on January 12, 2010 at 08:37:09 from (68.247.145.128):
In Reply to: C-123 Camshaft posted by Montana Rancher on January 11, 2010 at 19:55:21:
Hal has given you good info, the most common cause I have seen for low oil pressure is the warped bottom plate on the oil pump, 2nd is a previous engine "inspection" by a well meaning person who put the bearing caps back in wrong places.
When looking for damage from oil starvation around the cam, check for lobes that are starting to round off and concave lifter faces. I just finished rebuilding a C that had low oil pressure and I had to replace the cam, lifters and the rocker arm assy; but that would be unusual for a motor maintaining avg pressure.
