Posted by Montana Rancher on January 11, 2010 at 19:55:21 from (121.33.220.28):
I am about to overhaul the engine in my 230 and am a bit confused about renewing the camshaft. According to my IT manual there are no camshaft bearings. Is the camshaft something that just does not wear out ? About all I find parts wise are camshaft gears. Also what about the lifters? The engine is currently in use with little to no oil pressure and low compression. Thanks in advance.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
