Re: 130 hydraulic pump leaking
Posted by Jim Becker on January 12, 2010 at 17:00:59 from (173.57.141.22):
In Reply to: 130 hydraulic pump leaking posted by S MacKay on January 12, 2010 at 07:07:45:
Unless there is something really wierd, like a cracked housing or such, there are essentially 3 ways oil can get out of that pump to some place it doesn't belong.
1) leak past the seal (4), as has already been covered. A leak here will dump the oil into the engine.
2) between the 2 pump housing halves (5, 14). This is sealed by an o-ring (13) in a groove.
3) between the pump housing (14) and the manifold tubes (not in the picture). This is sealed by a pair of o-rings, one for each tube.
You should be able to thoroughly clean up the area then isolate whether the leak is at 2 or 3.
