Re: 300 U shifting problem
Posted by BMD on January 12, 2010 at 19:59:23 from (65.254.172.6):
In Reply to: Re: 300 U shifting problem posted by nspec on January 12, 2010 at 10:25:32:
Yes, it is the same shift pattern.
Thanks for the tip about removing the cone so you can see whats happening inside the shifter.
How did you go about cleaning the rails since the bulk of them are up under the transmission cover?
Thank you for your reply
BMD
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
