Re: distributor
Posted by glennster on January 13, 2010 at 09:10:47 from (76.217.99.179):
In Reply to: Re: distributor posted by Kevin in MI on January 13, 2010 at 08:52:35:
if you are using a toggle switch, you will need to tap power from the battery, run the wire thru the switch and then on to the power side of the coil. if you are 6v pos ground, you will tap the neg post on either the battery or inside the light/ammeter box, then run that wire thru the switch to the minus terminal of the coil. the plus terminal of the coil then goes to the terminal on the outside of the distributor body. the mag plunger type switch was a single terminal switch that grounded the mag wire to the tractor chassis to shut the engine off.
