Re: Re: wd9 starting procedure
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Skip on April 29, 2000 at 06:05:16 from (208.4.82.46):
In Reply to: Re: wd9 starting procedure posted by Redfan on April 29, 2000 at 04:55:33:
I have a 48 ser# WDCB33502 and both levers are down or back to start. If it was left on "gas" when shut down the starting valves could be stuck open, this would result in similar cranking speeds. The ignition is also controled by the starting lever,so this is another "indicator".
Mine starts and runs very good, but when cold the choke is very touchy.
Good Luck, and let us know results
Post A Followup
: Re: Re: Re: wd9 starting procedure
