Hello Gene Bender
Posted by Thumbanger on January 13, 2010 at 16:59:18 from (98.134.242.143):
I asked a question the other day about my 48 C Farmall had a dished piston The serial # FMC 9649 D looked it up the D stands for 5000 altiude are the heads on them the same as the flat top pistons gas you said the dished pistons were distulate pistons.Also pistons are a nice tight fit in sleeves do I need to change them or can I ring it and just run gas. Can the head be run with flat top pistons. Thanks for any info. James
