Re: Hello Gene Bender
Posted by Charles E. McNelly on January 13, 2010 at 17:47:15 from (72.18.77.250):
In Reply to: Hello Gene Bender posted by Thumbanger on January 13, 2010 at 16:59:18:
I don't want to jump on Genes thread but when you look at the piston, have the rings installed on it and check the gap between the ring and ringland. I wouldn't think anything more then about.004 would be considered good. You don't want the piston rings bouncing up and down. As far as pistons, if you can get a step head piston, get them. The combustion chamber on your head is fairly large. Good Luck,
Charles
