down where the shifter linkage goes into the trans there is a double roll pin. check that first. If it needs replacement do not use bolt as they will shear off, I have replaced thousands of them and I can tell you that even a grade 10 bolt will shear off. If it is sloppy like I have seen then this is you problem but it could be up in the shifter just off the side of the dash.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
