Re: HELP! 1466 with VERY sloppy inner trans shifer, .......
Posted by caterpillar guy on January 19, 2010 at 21:33:29 from (172.162.65.66):
In Reply to: HELP! 1466 with VERY sloppy inner trans shifer, ....... posted by Agman55 on January 19, 2010 at 19:15:02:
Mike has it right or if the detent for the lever is soft /weak/or whatever you want to call it you will have to pull the lid under the cab to fix it. Check the pins on the vertical shaft if not there then its under the lid. While in there look at the detent cam ,for the position selection as they wear out and then it wont stay in location for the speed you choose.
