Start at the top with the gearshift lever and work your way down to the transmission. There are several ball joint connectors and places where holes will become worn. I replaced most everything on my 1256 last winter and it wasn't a bad job. Of course my tractor didn't have a cab. If it had a cab it would be a real PIA. If you go to a Case-IH dealer and find a good parts guy that is familiar with these older tractors you will do okay. My dealer sold me a kit from Hy-Capacity that contained one or two steel pieces that I think were basically the range selctors that the gearshift handles mesh into. That was kind of hard to get off and it almost has to be pressed back on. That little update helped mine a lot and I also replaced every linkage and roll pin that I could. As others mentioned you might need to pull the range cover off and see what is worn inside. As far as the frontend goes it sound like it is okay. The front axel should pivot and that cylinder doesn not have any ends on it. Good luck.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
