440roadrunner said: I doubt that he's got a variable supply or he probably would not be asking, but I'm not convinced that your method will work?????
A cutout has a series and a shunt winding. The shunt winding is the "voltage" winding, seems to me you'd have to connect the power supply to the A (G) and ground of the regulator, but it would be MORE accurate to watch for the voltage regulator relay to click in, no?
The regulator would have to be grounded for this test to work. I have never tried testing this way, but suspect that a 6/12-volt battery maintainer is all the variable power supply required. With the maintainer set at 6, a 6-volt cut-out should kick in and a 12-volt not.
I also think the test can probably be done without a battery, just connect a voltmeter between the regulator ground and BAT terminal.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
