Re: Voltage Regulator Rating
Posted by Janicholson on January 22, 2010 at 07:24:51 from (199.17.6.222):
In Reply to: Re: Voltage Regulator Rating posted by Jim Becker on January 22, 2010 at 07:16:07:
I think it would, I did it on a jeep once to see if the regulator was working (cutout relay) and you are correct I left out the regulator ground (to the positive side of the Power supply). In my jeep test the regulator was grounded to the system I was messing with. I just forgot that the pull in winding uses that ground to work. Tom found it below. Jim
