Re: 5288 Steering?????
Posted by tjiniowa on January 23, 2010 at 09:54:18 from (207.177.45.244):
In Reply to: 5288 Steering????? posted by crg1978 on January 21, 2010 at 15:55:41:
If you have manual it is pages 92-94. Remove the plug that is below the rear cartridge filter cap, it is at about the 7 o clock position, this is the main filter drain plug, may loose a gallon or two, but doing this will close an internal check valve. Be sure to clean the relief valves located with the filters. Replace all three filters, sounds like it hasn't been done for a while. I change mine at least once a year, depending on hours. If you need diagrams of what I have told you let me know, I may be able to scan out of my manual.
