Re: Farmall 400 Steering
Posted by SDE on January 26, 2010 at 06:56:36 from (174.124.13.81):
In Reply to: Farmall 400 Steering posted by Matt Weltz on January 26, 2010 at 05:45:35:
If you have already went through your 300, you will already be aware of what you will need to do on the 400. Alot of the slop may be in the nut being loose by the worm gear that is on the shaft. The bearing wears and the nut will need to be tighten.
SDE
