Posted by Stephen McCoy on January 26, 2010 at 12:06:10 from (207.165.188.44):
I have a 1945 Farmall B that my students and I are in the process of restoring. When we drained the oil the first thing to come out was nice bright green antifreeze, followed by the oil. I have pressurized the radiator and looked for leaks around the sleeves (suspected lower o-ring may have been bad on sleeve) and have not seen any leaks around them nor are there any coming down the oil galleys from the head (suspected headgasket).
What I have seen in a very faint hairline crack in the block on the inside of the crankcase just behind the carburetor. I saw a couple drops of antifreeze there when I first had the oil pan off. I wiped everything dry before we began searching for leaks. After sitting for the weekend I noticed a few drops of antifreeze under the tractor right below where I saw the drops in the crankcase. Sure enough they we back in exactly the same spot I first saw them! It looks like there is some weeping coming through what looks like a crack on what would be the bottom of the water jacket into the crankcase.
Any ideas of how I can stop this leak short of replacing the block? Here's the picture I was able to take of the leak. What look like little bumps in the casting are actually the drops of antifreeze/water. The apparent crack starts from the far left drop and goes horizontally across to the right. Thanks.
This post was edited by Stephen McCoy at 12:07:40 01/26/10.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
