How did you pressureize the radiator when the radiator is vented thru a tube on the left side draining down below the fan. The crack on the outside wont hurt and can be easy repaired. I would remove the pan then with coolant full look to see if there is a leak at the bottom of the sleeves as the rubbers sealing them can leak. This is a wet sleeved engine. There are many places for soolant to leak into the oil but the rubber washers at the bottom of the sleeve is the bigest cuse. Remove the pan and let it set for a couple of days to check the sleeve for leaks. The radiator is not made for putting pressure as that engine uses the thermo-syphon system and is not pressureized.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
