Super A clutch and oil leaks
Posted by wobbly cart on January 29, 2010 at 13:38:06 from (67.142.161.30):
My Super A won"t even make it up the driveway anymore because I think the clutch is soaked in oil. Slows/stops movement when I load on the cultivators in the field. The touch control leaks profusely on the outside so I was assuming this was running down onto the clutch somehow. A neighbor says "no way" and suggested the problem is the rear main seal leaking on the clutch. Anyone have any suggestions or experience with this? Is the seal accessible under the oil pan? Is there a half-way reliable way to dry out the clutch once I fix the leak or is splitting the tractor inevitable. If it"s not the hydraulic oil getting on the clutch should I live with that leak one more season till I have the whole winter ahead of me again or is a rebuild pretty straight forward with cleanliness and care? Thanks
