As the others have said, it isn't the Hydraulic. If the clutch is soaked, it is possible to remove it, but not reasonable to try to clean it. If just a little oil got on it it would not slip. If a massive amount got on it, the soaking gets into the fibers and the solvent good enough to remove it with 4 or 5 soakings and rinses and such would still leave oil in the fibers. I would just buy a new disk. Check the Pressure plate for worn pivot points on the levers and checking and warpage. Always replace the T.O bearing and pilot bearing as well. Good luck, Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
