Posted by John T on January 31, 2010 at 06:39:28 from (71.55.31.109):
In Reply to: OT-Aux Generators posted by Dellbertt on January 31, 2010 at 05:57:30:
You cant hook up two gensets UNLESS they are in sync.................Remember they are producing a 60 Hertz sine wave so they MUST be in sync............
Its safer to use a proper TRANSFER SWITCH or at least one of those cheaper sliding main breaker lock out devices to feed loads (via the panel) if yourse using your existing panel and backfeeding it with the genset. DO NOT (well DUH) backfeed a panel unless its main is open because you can backfeed the utility primary High Voltage system and kill someone, thats the purpose of transfer switches
If youre using the genset (as 120/240) and feeding 120/240 TO THE PANEL VIA A TWO POLE (ie youre NOT switching the Neutral) TRANSFER SWITCH OR MAIN LOCKOUT you should sever any existing Neutral to genny frame bond in the genny.
Its okay to use the genset to feed plug and cord connected appliances via the gensets onboard receptacles (WITH the Gennys Neutral then bonded to its iron frame) with no other grounding electrode
DO NOT be using jury rigged plugs that have hot terminals exposed
I hope the other gents can add to this as Im sure I missed a few safety issues
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
