Re: Removal of final drive on left side of Farmall B
Posted by mkirsch on February 01, 2010 at 06:26:18 from (64.80.108.55):
In Reply to: Removal of final drive on left side of Farmall B posted by Paul Brueggeman on February 01, 2010 at 04:31:51:
The only thing holding the differential shaft in place is a lock ring on the outer bearing.
When you remove the final drive housing, the shaft should slip out of the differential and come with the final drive housing.
It may be binding because of the brake drum.
