Removal of final drive on left side of Farmall B
Posted by Paul Brueggeman on February 01, 2010 at 04:31:51 from (131.61.211.15):
I am trying to remove the final drive aseembly and I cannot get the long shaft out of the differential because it seems that there is something holding the shaft. I have everything apart on the final drive but the gear at the end of the shaft seems to be to big and I need to remove the shaft to pull th efinal drive assembly off. Is there something i am missing here. Maybe do I have to pull the differential bull gear to get the shaft out of this?
