Super MD break in
Posted by Andrew Z on February 01, 2010 at 09:44:04 from (64.252.113.90):
I have my Super MD all back together and about read to fire it off. I ground the valves, and put new rings in it, amount a few other things. Anyway I have rebuilt many gas powered engines over the years, yet this is my first diesel. Is there any special way to seat the rings? What i have been doing in the past is run it up to temp shut it down retorque the head, this would be within the first 20 mins or so. After this run the engine up to 3/4 speed and vary the rpms around under med load, this would be done for a couple of hours. Then full load and there after. Any thoughts if i should do something diffrent?
thanks
Andrew
