Re: Super MD break in
Posted by rustred on February 01, 2010 at 17:14:15 from (74.198.148.45):
In Reply to: Super MD break in posted by Andrew Z on February 01, 2010 at 09:44:04:
OK, sflem 849 I will try and make it more clear.there is ABSOLUTLY NO WAY you will have diesel compression at the spark plugs in the gas chamber while running on diesel if the little valves are doing their job. that is another reason not to switch it to gas and leave them open because they will warp AND then u will have diesel compression leaking to the gas side. from what you said, yours are leaking ...clear as diesel smoke?
